Ansys Products
Ansys Products
Cannot access flexlm from external
    • Jon Schlipf
      Dear support,
      Our group uses the 5-license Lumerical research package for university research. We access the server both from inside and outside the University network. After renewal of our license on December 12, we are not able to access our licenses externally, only internally. Is there a shift in policy, or does anything have to be reconfigured in the license server?
      Thank you and best regards
      Jon Schlipf
    • Lito Yap
      @Jon Schlipf,
      Please consult with your IT to configure the license file/Ansys license manager with static ports and allow access to these ports used by the Ansys License Manager from outside your University's network.
      Ansys license manager configuration and license file installation – Ansys Optics
    • Jon Schlipf
      Thanks, that did the job!
      I had only set the 1055 port, not the 1056. When setting both ports, it works.
      Interestingly, it seems like I do not need 2325. It is sufficient to either ssh-forward the other two ports, or open the firewall for them.
      Best regards
      Jon Schlipf
    • Lito Yap
      @Jon Schlipf,
      Glad to hear this. We typically open or add these ports used by the Ansys LM to exception rules in the firewall. We don't forward them to other ports to avoid any issues.
Viewing 3 reply threads
