March 7, 2022 at 1:06 pm
jordankim
SubscriberI tried to 'run analysis' from variables of Result View.
In this figure1, the 'P_vs_theta" cannot find and analyze but, others can caculate and visualize the result.
So I checked the script of analysis corner of 'farfield'(please look at the figure2)
March 9, 2022 at 7:08 pmGuilin Sun
Ansys Employee"the 'P_vs_theta" cannot find and analyze", have you re-run it? since the script does not give any error message in creating the dataset, I would suggest that you clean the work space, run the script again. Make sure each parameter in the dataset is correct and has consistent dimension to "P".
You may also retrieve the parameters inside P_vs_theta if you can see it in the workspace.
- Error on Lumerical device
2630
2110
1335
1110
461
