Cannot Calculate u+ using Custom Field Functions
    • Mitchell Durbin
      I am doing a project related to turbulent flow boundary layers. I am attempting to calculate u+ so that I can make a plot of u+ vs. log(y+) along a line normal to a nozzle wall.
      I have defined u+ in the following way:
      However, a contour plot of u+ in my domain shows that u+ is zero everywhere.
      I suspected that perhaps either the velocity magnitude, wall shear stress, or density are also zero everywhere, but that is not the case:
      Interestingly, the following custom field functions also resulted in a contour of zero everywhere:
      And, the following custom field function resulted in nan everywhere.
      Clearly there is something going wrong in the custom field functions when "wall-shear" is involved. However, as mentioned above, the wall shear stress itself is NOT zero anywhere.
      How can correctly define u+ to avoid this issue?
      Wall shear is technically zero on your contour as it's calculated on the wall. You're displaying on the fluid domain.
    • SRP
      Try to create custom function for u_tau then u/u_tau.
      Thanks
