Ansys Free Student Software
Topics cover installation and configuration of our free student products
Cannot display my model in Design Modeler
    • Kong Chun Fung Winston
      Hi:
      Seem that my Ansys is malfunctioning, the inserted geometery model cannot be displayed in the XY plate after I pressed the generatation button. Only there are some dot lines displayed when I moved the cruser near the object. Does anyone faced to this problem?
    • Aniket
      Your import seems to have some issues, as it has a yellow check mark instead of green when it succeeds. You can right-click on the import and click on show errors.
      -Aniket
      Dear Aniket:
      Thanks for your reply. However, this issue happened when I re-installed the Ansys 2023 R1. Even I drawn a retangle and used the rotation function to draw a Cylinder, the cylinder volume did not generate after pressing the generation button.
      My cylinder is using a retangle and rotated at Y-axis, it was selected as "Add frozen" function. However, the cylinder volume cannot display, only the dot lines will be showen when my curser is getting closer to it.
      Actually, when I re-installed this Ansys 2023 R1, there is an error that the VC_redist.x64.exe cannot be installed, I downloaded the VC_redist.x64.exe so that the program can be started normally. However, this fault happened. Even I cannot find my model in the mesh window.
      May I know this is the software crashed or setting problems. Thanks!
      Winston
      Dear Aniket:
      Thank you for your reply. I am actually using my MACBook Pro with Parallel Desktop software to run a virtual Window 11. Here are some hardware as shown below.
      1. Apple M2
      2. 16GB LPDDR5 RAM
      3. 256GB SSD
      4. Graphic card presented
      Please let me know if there are further requirements of my computer.
      Thanks!
      Winston
Viewing 3 reply threads
