March 11, 2021 at 11:55 am
OmkarE11
SubscriberI am trying simulation of impact of a cricket ball on a bat. I carried out the simulations with materials I added in a different materials library. But when I try to solve it shows an error 'Solver initialization error - see log file for more details'. When I do it with structural steel as the material it works fine. Please help.n -
March 12, 2021 at 7:44 am
1shan
Ansys Employee,nCould you click on solution information and tell what you see. You may want to check this out https://forum.ansys.com/discussion/22268/solver-initialization-error.It might be a a material element compatibility issue. What material are you using?nRegards,nIshan.n -
March 12, 2021 at 9:46 am
OmkarE11
SubscriberI created and added new material defining it by the viscoelastic and other properties. If not explicit dynamics will it work if I try transient structural analysis? n -
March 12, 2021 at 11:23 am
OmkarE11
SubscriberThe material for the ball has long term shear modulus. I am unable to find it while adding in properties of the material. I found rest of the properties which include density, bulk modulus, instantaneous shear modulus and decay constant. Please help.n -
March 20, 2021 at 1:56 pm
ramgopisetti
Subscriberlets break this in simple terms, The ball is usually an rubber material , which means there are models such as Odgen,Mooney-Rivlin . Yeoh, Arruda-Boyce model or any hyper elastic material will do, the following is the sample response recreated with your initial idea.npost down what exactly the material model you want to employ for further help.nRamn
Viewing 4 reply threads
Trending discussions
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
Top Contributors
2688
2138
1349
1136
462
Top Rated Tags
