June 17, 2023 at 4:06 am
mark sanders
SubscriberHello,
I have a geometry STL file and I converted it to solid geometry using SpaceClaim. I'm trying to combine two solid bodies. Errors come out, some are fixed, but there are no following problems.it is not possible to delete these edges either through delete or through "f", writes it is not possible to delete edges
Also, an error is issued with other bodies.
Cannot merge bodies. (Operation failed because the faces and edges would combine in a way that does not form a valid solid or surface.)
https://drive.google.com/file/d/1H-WlXML36AlnSuC5oQIdkNMpCsGRtvvT/view?usp=sharingHelp me please.
June 17, 2023 at 11:15 am
Nikhil Narale
Ansys EmployeeHello,
Could you try to resolve the additional edges by using the Repair - Fix - Extra Edges feature? Let's see if this resolves the issue.
Also, could you please make the second body visible and provide a screenshot?
June 17, 2023 at 6:21 pm
June 17, 2023 at 11:17 am
Nikhil Narale
Ansys EmployeeFYI, Ansys employees are not authorized to download any attachments from here.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7578
4424
2949
1422
1322
