Tagged: 3d-geometry, ansys-spaceclaim, ansys-student, spaceclaim
February 18, 2022 at 5:55 pm
gerardsoldevilla99
SubscriberHi.
I am trying to merge a pair of symmetric bodies. The full geometry is basically a plane split. I am using the operation combine, it should work because the right-hand body was created with an operation mirror.
February 21, 2022 at 4:04 amKeyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Another operation you can try is -
Delete coomon face of both solids and then use Stitch operation.
Regards Keyur
March 6, 2022 at 7:37 pmMarch 7, 2022 at 8:33 amKeyur Kanade
Ansys EmployeeSelect all faces  right click  detach all
Then again check.
Delete faces which has errors. Recreate them.
Use repair stitch.
Please go through help manual for more details
Regards Keyur
March 7, 2022 at 10:02 amgerardsoldevilla99
SubscriberThank you very much, it worked. First deleting the conflicting faces. Then it was not possible to merge in any case. But I solved as you proposed in your first reply, thank you very much.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
