July 18, 2023 at 1:31 pm
Alessandro Stanzione
SubscriberHi i have a problem with fluent : in design modeler when i want to import a profile from a file it says " error loading coordinates ". I use the 2020R2 version and the file is openend normally by anyone exept me and i connt figure out why ; I ve tried formatting computer more than 5 times but nothing. I d like to attach the file i need to open here but idk how to do so( i attached an image instead). Anyway its just me who cannot open that file and idk why .I currently use windows 11 but i ve tried with 10 as well and the problem is the same.
July 19, 2023 at 4:16 am
mjmiddle
Ansys EmployeeI see you are using European decimal separator, which is a comma. This is set in the operating system. Try setting to a dot. Beware of any empty lines also.
https://support.talkdesk.com/hc/en-us/articles/360047099811-CSV-Files-and-Regional-Settings
- How to move duplicated ansys project position in workbench GUI
- unable to open files in ansys
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Error: Unable to open some designs in this project – Corrupted project files
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- ANSYS Multi field 2-way FSI data coupling issue
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- Material constant Damping calculation
- How to export high resolution images in APDL
7742
4502
2961
1449
1322
