Cannot re-run ANSYS Hydro-Diffraction after changing CG PACC OPEN OLD FILE FAILED
    • riyanto.r
      Hi all,
      I have a very frustrating error where I cannot re-run all my simulation after only changing the Z CG, it says:
       DAOPEN: Open failure on file - ANALYSIS.VAC.
       PACACC:OPEN(OLD) FILE FAILED. FILE:ANALYSIS.VAC.
       TERMINATED WITH ERRORS.
      How can I resolve this problem? I don't think that this is from my model error because last time I run it, everything was fine until I raise the Z CG by only 2 meters.
      I cannot afford to remodel all over again due to time limitation.
      Please help urgently because the deadline is coming near
    • Mike Pettit
      If you have not done so already, please follow the workaround instructions in this post: PLT file when using WORKBENCH AQWA ÔÇö Ansys Learning Forum
      Let me know if this does not work, and we can try to investigate further.
      Cheers, Mike
    • riyanto.r
      Hi Mike,
      It turns out that ANSYS has interference with the Microsoft OneDrive when it tries to sync the old solution file. The solution is to kill OneDrive when I run the ANSYS Simulation.
      Thank you
    • Mike Pettit
      I'm happy to hear that you got this resolved, and thanks for sharing your solution here.
      Cheers, Mike
Viewing 3 reply threads
