Discovery Import
Discovery Import
Cannot select correct activation code in portal
    • paul
      Is it possible to add a button to the portal so we can assign the correct license?
      Currently you cannot do this and the portal chooses the wrong one everytime. This is very anoying because i am not able to login with the customer and have to use the command prompt to specify the correct activation code.
      Kind Regards,
      Paul
    • Devendra Badgujar
      Hello Paesc
      Let me check and get back to you.
    • Devendra Badgujar
      Hello Paesc
      Yes currently it is not possible. I will create an enhancement request for this functionality to be added.
      Regards.
