November 18, 2017 at 8:25 pm
mbuckley5689
SubscriberHi All,
I've been wrestling with a very frustrating problem for many hours.
I cannot start my DesignModeler Geometry.
I'm running ANSYS Student 18.2. When I try to run Design Modeler Geometry, I get the message: AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersmeAppDataLocalTempAnsysWBDumpFile.dmp
I've tried changing the name of the .ansys file in the %temp% folder and changing the name of the ansys file in the %appdata% folder. This didn't work. I tried adding a new system variable called: ANS_OLD_ATTACH and setting the value to 1. This did not work.
Does anyone have any suggestions on how to fix this problem? I've desperately been trying to fix it to no avail.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
