Discovery Import
Discovery Import
Cannot start SpaceClaim (again)
    • sam
      Ref https://discoveryforum.ansys.com/t/h7hdv82
      It worked for a day, but back to not working again.
      Seems there is a license server it's not getting a response from...
    • Charudatta Bandgar
      Hello Sam Whitney
      What had helped it work again previously? Have you tried the troubleshooting 5A as suggested? It could be possible that the firewall/antivirus could be causing this. Could you disable the firewall and try launching it again, just to be sure? I will discuss in the team and see if there is any other reason for this.
      Regards.
    • sam
      I don't know of anything different on the machine between it working fine, stopping working, working and then not. There wasn't anything that I did that made it work on Friday, it just worked like normal.
      I'm running windows defender, no third party AV or firewall.
      I did the troubleshooting - in other thread is the successful ping.
      From what I can tell, the splash screen loads and it seemingly puts in a request to check the license. This seems to time out, as it sits there for a couple of minutes every time.
      When it times out it displays a login box, which when submitted it then tries for a further period, some minutes later it times out and displays a message saying the license couldn't be found.
      It gives the option here of starting SpaceClaim in View Only mode; which starts up fine, but is of course not much use.
      From what I can gather something remote isn't responding and evidently SpaceClaim is inoperable when this happens?
