Cannot store element
    • uzzzz
      Hi everyone, I have an error and i can't seem to find a solution to it on Ansys Forum and anywhere else. The error is: 'The en command cannot store element 180829, possibly because one or more nodes is not defined.'.
      Could someone please help me with this?
    • 1shan
      What element type are you using? Make sure that the number of nodes is consistent with the element type used.
      Regards Ishan.
    • uzzzz
      How do i check whether the number of nodes is consistent with the element type used? Under mesh details, I saw that the number of nodes and the number of elements are different.
    • 1shan
      You must have used a command snippet defining element type with ET command right ? This is a similar thread you can check https://www.eng-tips.com/viewthread.cfm?qid=178732.
      Regards Ishan.
    • Mike Rife
      you seem to be using WB Mechanical so try clearing the generated data on the mesh. Then re-mesh and solve. What happens?
      Mike
    • uzzzz
      Yep it works, thanks!!
Viewing 5 reply threads
