September 22, 2020 at 11:37 pm
September 23, 2020 at 2:41 pm
Forum ModeratorThink about the rate of heat transfer. If a heat sink is good how much of a temperature gradient should you see on the metal part? nFor the wall HTC (top image) if you alter the scale what do you see? Try 0 to 5 W/m2/K and compare with what you plotted. n -
September 23, 2020 at 3:10 pm
spacemandan
SubscriberI Just tried to do that, and it still shows zero. I configured this to be a conjugate heat transfer problem. In design modeler merged all the bodies into one part. In the boundary conditions, the interface between the fin and the fluid is coupled. I am not sure what else I am missing?nn
September 23, 2020 at 3:58 pm
Forum ModeratorWhich wall of the wall - wall:shadow pair are you displaying?n -
September 23, 2020 at 10:36 pm
spacemandan
SubscriberI am displaying the wall, not the wall shadownn -
September 23, 2020 at 10:40 pm
spacemandan
SubscriberI see now, it works with the wall shadow. Thank you! Is there any reason for this?. -
September 25, 2020 at 11:02 am
Forum ModeratorIt's a fluid side property, so doesn't exist on the solid side. Ie the HTC is from the wall to the fluid. If you had a fluid on both sides of the thin wall the values for wall & wall:shadow may be different; heat flux would match though. n -
September 27, 2020 at 5:05 am
spacemandan
SubscriberYou are a genius, thank you!n -
September 28, 2020 at 10:39 am
Forum ModeratorYou're welcome, I'm going to screen grab your comment for my boss
Viewing 8 reply threads
- The topic ‘Cannot View Heat Flux on plane Surface’ is closed to new replies.
Trending discussions
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- convergence issue for transonic flow
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- Point exception in erosion calculation
- Script Error Ansys
- Errors with multi-connected bodies using AQWA
Top Contributors
2567
933
792
599
591
Top Rated Tags
© 2025 Copyright ANSYS, Inc. All rights reserved.
