March 23, 2021 at 8:41 pm
prakhars962
SubscriberI am trying to use Python to add symmetry region (along edge 21) in my Solid simulation as follows:
SlMn = ExtAPI.SelectionManager
SlMn.ClearSelection()
Sel = SlMn.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
import context_menu
context_menu.DoInsertSymmetryGroup(ExtAPI)
symm=context_menu.DoAddSymmetryRegion(ExtAPI)
Sel.Ids=[21]
symm.Location=Sel
After, running the code I can see the following:
March 31, 2021 at 4:22 pmAniket
Ansys EmployeeTry using following two lines instead of the context menu method that recorder records:nmySym=Model.AddSymmetry()nmySymReg=mySym.AddSymmetryRegion()nnAnd then add the location as given in the code. Note the IDs can vary depending on geometry.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 1 reply thread- You must be logged in to reply to this topic.
2726
2156
1359
1150
462
