November 30, 2020 at 12:11 am
ah05085
SubscriberHello,
I'm having trouble doing a bearing load simulation. I can't apply the load to my inner rotor diameter surface.
November 30, 2020 at 1:55 ampeteroznewman
SubscribernPerhaps Bearing Load only works when you have a complete cylindrical hole. You have a half cylinder. Try it with a complete cylindrical hole.nDecember 8, 2020 at 2:36 amah05085
SubscriberThats what i did 1st. Do you think the body has to be 1 entity without many faces?nViewing 2 reply threads- The topic ‘Can’t apply bearing load to inside surface of rotor’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8832
4658
3159
1688
1482
