Can’t change sizing method for generate volume mesh
    • chstan
      On page 308 of the Fluent 2021R2 User Guide, it states that there is an option to select "Region-based sizing" for the sizing option in the Generate Volume Mesh task within the watertight meshing workflow.
      In my Fluent meshing window there is no option to select a sizing method, and the user guide doesn't provide any information on enabling the sizing method option for Generate Volume Mesh tasks. How to I enable the choice between sizing method options?
    • chstan
      update: the sizing method dropdown menu has now appeared. I think it was related to the local sizing - at first I had local sizing enabled and the sizing method menu wasn't visible. Now that I've turned it off it is appearing.
