April 29, 2022 at 5:50 pm
czadeh
SubscriberHi,
I just installed ANSYS Fluent 2021R2 and Rocky 2021R2 through files and licenses provided by my University.
When I try to run Rocky by itself, it brings up the license management page, I click ok, then it closes and nothing happens.
When I open Workbench and use the Particle Dynamics (Rocky 21.2) system, it says "Can't communicate with the wrapper Rocky instance."
There are also the following details about the error:
Ansys.AnsysRocky212.Communication.ApplicationCommuncationError: Can't communicate with the wrapper Rocky instance.
at Ansys.AnsysRocky212.Addin.ThrowError[ExceptionType](String msg)
at Ansys.AnsysRocky212.Communication.WbSideRockyWorkbenchApi.WaitRockyInterface(Boolean throw_exception)
at Ansys.AnsysRocky212.Communication.RockyCommunication.CreateRockyWrapper(DataContainerReference container, String active_dir, Boolean gui_required, Boolean erase_results)
at Ansys.AnsysRocky212.Communication.RockyCommunication.ObtainRockyWrapper(DataContainerReference container, String active_dir, Boolean gui_required, Boolean create_if_needed, Boolean erase_results)
at Ansys.AnsysRocky212.Commands.LaunchRockyForConfigurationCommand.Execute(IFullContext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Can't communicate with the wrapper Rocky instance.
CommandName: AnsysRocky212.LaunchRockyForConfiguration(Container="Setup 1")
at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.AnsysRocky212.Commands.LaunchRockyForConfigurationCommand.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Object CanDeleteResults)
at Ansys.AnsysRocky212.Gui.EditRockyGuiOperation.Invoke(GuiOperationContext context)
at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
Is there any way to resolve this error and get Rocky to start?
Thanks
May 3, 2022 at 2:04 pmRob
Forum ModeratorDo you know if the Rocky files were from the Ansys website? The licencing changed with 2021R2 so if you've got ESSS Rocky and not Ansys Rocky you may have a (easily fixed) problem. Otherwise, if you install and configure Ansys first Ansys Rocky should install and pick up the licence automatically.
Viewing 1 reply thread- The topic ‘“Can’t communicate with the wrapper Rocky instance.”’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
8808
4658
3153
1680
1470
