June 22, 2019 at 11:24 pm
Raphael
SubscriberHello,
I get the following error when I attempt to create a discussion in any other section:
Access Denied
You don't have permission to access "http://studentcommunity.ansys.com/topic/create/" on this server.
Reference #18.cdfc0a17.1561245718.f897c6b
June 25, 2019 at 12:16 pm
Ansys EmployeeAnd weirdly this didn't show up until today. Try clearing the browser cache and/or use a different one, that seems to fix most problems. From checking there's nothing in the moderation list and no flags against your ID.
Edit: I've even had to approve my own post! Is the site still blocking you?
June 25, 2019 at 7:17 pm
Raphael
SubscriberStill not working. I tried clearing the cache and Google Chrome (I was originally on Pale Moon, a Firefox variant). Nothing worked. All of this was today after your reply.
If you had to approve your own post then I assume it's not just me.
June 26, 2019 at 6:13 am
DrAmine
Ansys EmployeeI needed to approve your last post. Sometimes this is required...
June 26, 2019 at 6:26 pm
Raphael
SubscriberHowever my inability to create discussions in other sections remains. Is there something that can be done about this?
Alternatively, maybe I could post the intended text here or send it in a message and someone could post it in the appropriate forum on my behalf?
Or could I post it as a discussion here and a mod/admin could move it to the appropriate section?
June 27, 2019 at 3:24 pm
Ansys EmployeeYou can try that. I'll flag your ID internally to see if there's a problem with it.
April 16, 2020 at 4:24 pm
joaoalves
SubscriberHello,
Sorry, an error occurred while processing your request.
does anyone know why?
Thanks
April 17, 2020 at 8:50 am
Ansys EmployeeIf you're posting a long message break it up, and if you're using ( ) switch to [ ] as there's some syntax that causes problems [do NOT ask why.....].
April 17, 2020 at 9:18 am
joaoalves
SubscriberNo, the problem existed when I clicked start discussion but today it is already working! Thank you!
- How to access the ANSYS Online Help
- search does not work.
- Discussion Creation Error
- unable to open the saved ansys file.
- Regarding not getting link of click “accepted answer”
- Images added to Posts are scaled UP and down
- Access to ANSYS Customer Portal?
- Access Denied Error When I Send Post
- ACP module does not start
- Please delete member email
3820
2607
1853
1244
600
