March 15, 2022 at 12:52 am
fclandi
SubscriberHello guys, I'm trying to simulate a rack and pinion system and i'm struggling to set a new coordinate system created by me on the remote displacement configuration. The coordinatate system consist on a cylindrical with axis on Z and define dy global axis on Z, placed on the center of de pinion as the folow image:
March 15, 2022 at 5:34 pmGary Stofan
Ansys EmployeeSee if it will accept a Cartesian Coordinate System.
March 15, 2022 at 6:45 pmfclandi
SubscriberYes it accepts, but a I need to make a cylindrical one so I can rotate the pinion. There is a way out?
March 15, 2022 at 8:03 pmGary Stofan
Ansys EmployeeThe Remote Displacement has the control for X,Y,Z, and RotX, RotY, RotZ. You can constrain or allow rotation on any axis.
March 16, 2022 at 1:27 amfclandi
Subscriberthe error "Could not transfer loads and constraints to the solver." pops out
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2616
2098
1323
1108
461
