Discovery Import
Discovery Import
Can’t export results data to a .csv file
    • reinhardt
      Hi!
      Anyone knows how to export the results of a simulation in AIM when the button  doesn't appear in the contour panel?
      Thanks in advance.
      Greetings!
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Charudatta Bandgar
      Hello JaegerW ,
      Results data export as .csv is limited to steady-state fluid simulations, where only the following results can be exported:
      • Vectors on volumes
      • Contours on volumes
      • Contours on physics condition faces of fluid simulations.
      For more information, please refer to the AIM documentation
    • reinhardt
      Hi Charudatta Bandgar . Thank you for the answer!
      I'm trying to obtain the stress vs displacement charts of this simulation, is there any option inside AIM where I can do this, or the software has this limitation?
      Greetings.
        Hello JaegerW
        It is not possible to export these results as of now, but it will be a good value addition to the Discovery AIM. I would suggest you post it in the Discovery AIM ideas section, so the developers can take a look into it.
        Regards.
