March 22, 2021 at 2:09 pm
myvue
SubscriberHello everyone,
In the ANSYS Workbench (2020 R1), I cannot find the component that exports the .k file from ANSYS to LS-Dyna (Explicit Dynamics, LS-Dyna Export). I also checked the install log file and it shows me that I installed it. Could you please help? Thank you.
March 23, 2021 at 3:58 pmmyvue
SubscriberI uninstalled, and then reinstalled ANSYS, but the problem still persists.nMarch 24, 2021 at 3:26 pmGovindan Nagappan
Ansys EmployeenGo to Tools -> Options -> Appearance and turn on “Beta options” and also turn on “Unsupported Features”n======================nThe LS-Dyna Export does require a Ansys LS-Dyna licensenIf it still doesn't show upnClick on View all/customize at the bottom of the toolboxnnThen turn on the LS Dyna Export systemn
n============================nnLS PrePost can read in Nastran files. So, you can write out a Nastran file from Mechanical application. Being sure to set mesh pref to explicit. Then read it into LSPP and translate to k file.
March 25, 2021 at 1:48 pmViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2700
2138
1355
1142
462
