December 30, 2022 at 5:50 pm
Riccardo Bianchini
SubscriberHello, a few days ago I asked help with a mesh, now I have troubles for the validation of a flow around a NACA 4412. I'm trying at 6° but Cl is too low and Cd too high, tried different models and it's the same. Also tried a NACA 0012 with a different type of mesh and it's the same. I'm leaving a few pictures of the mesh and setup.
Probably I'm doing something wrong. Thanks.
January 2, 2023 at 5:15 am
SRP
SubscriberHi,
I recommend checking the AIC course for more information regarding the airfoil simulation: Flow over an Airfoil - ANSYS Innovation Courses
Thanks
January 2, 2023 at 10:45 am
Riccardo Bianchini
SubscriberAlready tried but had no luck. It seems that for 0° AoA I get the correct values, but as soon as I change that I get bad data.
January 2, 2023 at 4:17 pm
SRP
SubscriberHi,
Which turbulence simulation model did you use?
Thanks
January 2, 2023 at 6:55 pm
Riccardo Bianchini
SubscriberHi. I intended to use k-w SST, but have also tried k-e and S-A and I get somewhat similar results. Which would be good if they weren't wrong, there has to be something simple I'm missing but can't figure out what.
January 3, 2023 at 7:42 am
SRP
SubscriberHi,
Could you please send the screenshot of the following plot and contours:
1)Residual plot for zero AOA and 6 degree AOA
2)Cl and Cd plot for both AOA
3)Velocity/Pressure contour for both AOA
Thank you
January 3, 2023 at 9:17 pm
January 4, 2023 at 8:24 am
SRP
SubscriberHi,
Can you please uncheck pseudo transient to reduce error and re run simulation once?
Thank you
January 4, 2023 at 8:18 pm
January 5, 2023 at 10:57 am
SRP
SubscriberHi,
The issue might be with turbulence model and corresponding y+ use to create the inflation layer.
When using low-Re models or any models with enhanced wall treatment, the average Y+ value should be on the order of ~1 to ensure we are capturing the laminar sub-layer. When using wall function models, the Y+ value should ideally be above 15 to avoid erroneous modelling in the buffer layer and the laminar sub-layer. High quality numerical results for the boundary layer will only be obtained if the overall resolution of the boundary layer is sufficient.
I suggest to please check the y+ corresponding to the turbulence model used.
you can also create an additional variable for the eddy viscosity ratio. Then by plotting this variable , and superimposing mesh in the near-wall region, we can visualize the boundary layer resolution.
Thank you
2522
2064
1279
1094
456
