December 27, 2022 at 8:56 am
Zhu xiao
SubscriberIn Eddy current, i need to derive the inductance of transformer, and there some layer that connect in series and parallel.
In some case, there isn't result for the ReduceMatrix. But the Original matrix is pretty good showen.
What it the reson for the case no showen ReduceMatrix result? How can i fix this problem.
December 27, 2022 at 9:38 am
January 6, 2023 at 6:10 pm
GLUO
Ansys EmployeeHello,
I cannnot reproduce this issue. The reduce matrix calculation is just post-processing. If there is correct original matrix result, the reduce matrix result should be simply calulated from the original. Could you provide more details?
Thanks,
GLUO
January 8, 2023 at 1:03 pm
Zhu xiao
SubscriberI test different model (different layers of Transformer), try to figure out the patten,but in vain.
But it seems the layers of transformer more complicate, this fault result more eary to trigger.
January 10, 2023 at 3:03 pm
GLUO
Ansys EmployeeIf possible, please submit a service request in customer portal. Our techinical support engineers can exam your model and resolve the issue.
Thanks,
GLUO
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1285
1096
459
