September 28, 2017 at 2:21 am
aws3rd
SubscriberHello,
I have problems with geometry here. I've already drew some 3D drawings in Autodesk Inventor 2018. Then I open the Fluid Simulation in AIM and tried to import the geometry, but it said that the 'CAD translator for this flie type was not found'. Then I take an initiative to import this first in Geometry AIM but it didn't works.
I know if it could some compatibility issues because I also use newest version of Autodesk Inventor.
So is there any fix for this? Or any step which I missed?
Thanks.
September 28, 2017 at 9:52 am
Vishal Ganore
Ansys EmployeeI am not sure whether your are using student version or any other academic product. Please convert your file into neutral IGES or STEP file format and then try importing. It should work.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5290
3311
2471
