March 17, 2022 at 3:23 pm
Hatyk
SubscriberHello, I've been trying to import geometry into a mesher, but running into the same problem every time. Tried several geometries, even simple cube, but the result is the same. Can't find solutions online to this error.
Error log:
importing meshing model from PartMgr from file 'C:/Users/Ansys/Desktop/cube.scdoc' ...
setting enclosure and symmetry processing to False
setting transfer named selections to True
setting named selection prefixes to ''
setting mixed import resolution type to 'SolidAndSurface'
setting target application to 'FluentMeshing'
attaching to assembly ...
attaching to assembly failed after 121.021 [s]
running ANSYS TGrid CADToTGridConverter FAILED! (pIPartMgr->AttachAssembly() failed!
Unable to start CAD system.
Attach failed.
importing meshing model from PartMgr from file 'C:UsersAnsysDesktopcube.scdoc' failed.)
ran ANSYS TGrid CADToTGridConverter in 121.048 [s]
======== Command Execution Log Manager ========
Number of execution logs: 2
MeshingModelImportPartMgrExecLog
Label = 'ANSYS_MESH_FM_WARNING_ID_MESHINGMODEL_IMPORT_PARTMGR_ERROR'
DataTranslatorCommandExecLog
Label = 'ANSYS_MESH_FM_ERROR_ID_CONVERT_WORKBENCH_TO_FLTG_ERROR'
Error: Error in CAD Import
Error Object: #f
I am using Fluent 2021 R2.
March 21, 2022 at 4:27 amKeyur Kanade
Ansys EmployeePlease run CAD configuration manager. You can find some posts related to it on this forum.
Fluent - CAD Configuration Manager GUI Errors out on Startup ÔÇö Ansys Learning Forum
Please go through help manual for more details
If CAD configuration does not solve issue, it may need to re-install software or open a new post under installation category.
Regards Keyur
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2700
2138
1355
1142
462
