Kampus Merdeka
Kampus Merdeka
Can’t insert Body Interaction
    • faridnugroho21
      In the Second Simulation, in course 2, I cant set the body interaction. Even I copied setting for the Connections. Still, the Body Interaction solver cannot be set. How to fix this??
    • SaiD
      Hello. I see that you have probably used a "Transient Structural" system. There is a mismatch in the video between what is shown in the screen and the annotations. The annotations say "Explicit Dynamics", and for this case you would need an "Explicit Dynamics" system (although the screen recording shows "Transient Structural"). We will work to fix this. In the meanwhile, please use an "Explicit Dynamics" system and continue to follow the other steps in the video.
      When you use an "Explicit Dynamics" system, by default Body Interactions will be inserted for all the bodies.
      Hope this helps!
      • faridnugroho21
        Thank you for the answer sir.
    • SaiD
      Hello, glad that you found the answer helpful. Could you specify the course name under which you came across this simulation example? We will add the corrected How To video to the corresponding simulation.
      Thank you again for bringing this to our notice.
      • faridnugroho21
        It's in Course 2 : Strain in Deformation Analysis
