3D Design
3D Design
Can’t introduce decimals in spaceclaim
    • Laura Pérez
      I can not enter decimals in spaceclaim, when I put the comma it disappear and 12.2 transforms into 122 for example. I already checked the settings.
    • Saumadeep
      Hi
      Can you please check this SpaceClaim Help Link: Units options (spaceclaim.com)
      Saumadeep Choudhury
    • Laura Pérez
      I have all the settings correct
    • Saumadeep
      First, select - "Imperial" in "Type"
      Then select - "Decimal" in "Decimal/Fraction"
      Refer to the image attached.
    • Laura Pérez
      It works!. But after using the block recorder and setting some of the dimensions as input parameter. After that, suddenly I was able to set decimals.
      Thanks.
Viewing 4 reply threads
