can’t play the animation
    • avitalmic
    • Nikhil Narale
      Can you please elaborate more on the issue or the error you are encountering?
      Also, make sure you enter correct start and end frame (which is 0 in the attached image). Also check if the files (.hsf and .cxa) saved are for the selected animation sequence.
      Nikhil
    • avitalmic
      Hi once the simulation has done, I tried to play the animation but as you can see I cant change anything on the setting window. It seems like there's no data to play but I do see the files in the folder (yes, its the correct files..)
    • Kishan Konannavar
      Hello
      Maybe you can refer to this video if you haven't already. Hope it helps.
      " target="blank">ANSYS Fluent: Scene and Animation Creation - YouTube
      Regards
      Kishan
  • Nikhil Narale
    Can you share these two things:
    1: Screenshot of the 'Animation Definition' window. Make sure you keep the required one selected.
    2: Screenshot of .cxa file (First few lines would do).
    Nikhil
  • DrAmine
    Open a new Fluent session do load any case file just read the animation file there. Will that work?
  • avitalmic
    thanks everyone! I did again all the steps and run the simulation again and now it works.. I dont know what was the reason it didnt wotk the first time
  • DrAmine
    probably the file (*cxa) was corrupted. Anyway: you are now over it!.
  • Viewing 7 reply threads
