January 1, 2021 at 2:59 pm
January 4, 2021 at 2:07 am
Naresh Patre
Ansys EmployeeHello Andreas
The License Manager is required if you have a floating license of SpaceClaim. Since you have a named user trial license, you don't have to worry about the license manager and its messages. Simply close the license manager page and launch SpaceClaim.
Let me know if you face any issues.
January 4, 2021 at 10:04 am
andreas
SubscriberNaresh Patre thanks for your response! However I can't open spaceclaim from the windows toolbar (pics 1+2). This way there always opens an account login (Pic 3) which I enter and nothing happens. Doing the setup again leads to a notice (pic4) that I don't have right liscence and can only run a non-editable version - then the program opens (but I can't open. obj or. stl files). After closing the program it can't be opened again via the windows toolbar as mentioned above? I really appreciate your help and would test the performance of spaceclaim.
January 4, 2021 at 10:15 am
Naresh Patre
If the applications don't start, activate the Named User (Subscription) license manually through Command Prompt. Please refer to below article on activating the license manually through Command Prompt.
Discovery Subscription license - Command line options - Knowledge Base - Ansys Discovery Forum
Once the Named User (Subscription) license is successfully activated through Command Prompt, launch SpaceClaim or Discovery 2020 R2. The login page won't appear and you should be able to launch and use the applications successfully.
January 4, 2021 at 8:44 pm
andreas
SubscriberTook me some time to get the right Syntax but now it works! Thanks for helping!
3812
2593
1849
1244
600
