February 19, 2021 at 6:29 am
noob_to_pro_soon
SubscriberFebruary 19, 2021 at 2:10 pmKarthik R
AdministratorHi,nTo specify an offset, click on the 'Align' condition in your structure tree. You should be able to specify it.nKarthiknFebruary 20, 2021 at 3:46 amnoob_to_pro_soon
SubscribernHi,To specify an offset, click on the 'Align' condition in your structure tree. You should be able to specify it.Karthikhttps://forum.ansys.com/discussion/comment/107435#Comment_107435
Hello Karthik, really appreciate you trying to help, but actually, the align constraint that I make in the video does not end up being reflected in the structure tree (as you can see in the video, the structure tree does not change after the constraint is set at all). This prevents me to specify any offset because for me to click at 'Align' in the structure tree, 'Align' has to be there first. Please tell me if I'm doing something really stupid nFebruary 22, 2021 at 1:47 pmKeyur Kanade
Ansys EmployeeCan you please upload an image of your structure tree or entire SpaceClaim window. nIs there any specific requirement that you need to set offset? Can you use move tool? nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 3 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5364
3363
2471
1310
1018
