March 22, 2021 at 7:38 pm
prakhars962
SubscriberI was simulating a footing using symmetry. The right half is what I simulated and I can see the deformation. However, I can't see the deformation in the left symmetric part.
Is there anything I am missing?
March 23, 2021 at 1:48 pmGovindan Nagappan
Ansys Employee@prakhars962nnImage appears like you already have 2 half's displayed. If this is not expected, can you show the image of the model and a description of what is expectednnnIf you have symmetry in 2 directions see the example below, nmodel is symmetric about X and Z. So, set the type to cartesian, method to Half, enter a very small value of X & Znn
March 23, 2021 at 1:53 pmprakhars962
SubscribernI can't see the small indentation as a result of the deformation in the top- centre area in the both the symmetric parts.nThe indentation can be seen, only in the right part which I originally simulated.nMarch 23, 2021 at 3:02 pmGovindan Nagappan
Ansys Employee@prakhars962 nnTry changing the scale for result display and unit system to see if it makes a differencenAlso see if you can use the default legend. If it still doesnt work, consider using the APDL commands or APDL application for post processingnYou can use /expand command nSee example usage at 27.7. Results and Discussion (ansys.com)nnViewing 3 reply threads- You must be logged in to reply to this topic.
2688
2138
1349
1136
462
