March 10, 2022 at 1:28 am
rda
SubscriberI manage an ansys fluent installation, in the past I was able to define the ansyslmd port by editing the VENDOR line in the license file according to the syntax:
VENDOR vendor [vendor_daemon_path][[options=]options_file_path] [[port=]port]
in particular I use:
VENDOR ansyslmd option=/path/to/option/file port=1056
looking at the log files I see that the option file is correctly set but the port is not. I have tried using PORT instead of port but the behavior was the same.
Any ideas how to fix this?
Thanks in advance!
March 10, 2022 at 4:50 pmrda
SubscriberI forgot to mention that we are running Ansys 2021R2
March 10, 2022 at 5:26 pmrda
SubscriberI seem to have solved the issue (two license files were being read and while the options file was correctly read in the edited license file the port was not being set).
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2588
2080
1315
1108
459
