December 5, 2019 at 2:45 am
rahul5191
i am not able to select that body as a whole to apply load nor for anything. created by coordinates file by adding points and lines joining points. later did pattern. now this is like a truss and i needed to give load on the top face of the model and it highlights as only a line which i created when selecting via body.. even the face selection doesnt work for the i cross section i gave nor the body selection
December 5, 2019 at 3:06 pm
SubscriberLine bodies don't have faces, they are lines. You can pick the whole line or a vertex to apply loads. There are no faces to apply loads to.
Line bodies have cross-sections. You can visualize the cross-section by using View, Thick Shells and Beams. That is just to check things like orientation of I-beams, but it does not create faces that you can pick. Turn off Thick Shells and Beams, you will see only lines.
December 8, 2019 at 6:47 am
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5326
3311
2471
