August 23, 2017 at 6:13 pm
Ivanini
SubscriberHi,
I am currently trying to make a composite material static structural analisys. All parameters of ACP(Pre) are set but when I try to share setup information to a new Static Structural block the section in "Section Data" is missing. Also if I try to make the path like Figure 4.10 in https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/acp_ug/first_solid_wb-analysis.html but I can not share solutions from Static Structural to ACP(Post)
How can I share that?
On upload image is my currently workbench an as you can see "Section Data" is missing.
Thanks.
October 12, 2017 at 9:59 pm
ahmedshorab
SubscriberHey,
I'm having the same issue, did you end up figuring it out?
Thanks
April 5, 2018 at 6:51 pm
Carlos Enricque
SubscriberHi, I'm on the same problem, did you found any solver?
August 7, 2018 at 2:16 pm
tcoons
SubscriberHello, I too have run into this issue and have yet to find a solution. Did anyone figure this issue out?
August 7, 2018 at 2:25 pm
August 8, 2018 at 1:00 pm
cagdasakalin
SubscriberHi SandeepMedikonda,
I've tried many time setting ACP-Post as you posted.
But it does not make any connection between the solution cell of the static structural and results cell of ACP-Post.
I really could find out why?
Please give your suggestions.
Cheers,
Cagdas
August 8, 2018 at 1:31 pm
cagdasakalin
Yes, It works.
May 22, 2019 at 4:07 pm
Suryapratap086
SubscriberHI SandeepMedikonda,
I have tried your method but the problem is that I am using Explicit Dynamics and sharing setup of ACP Pre to Model of Explicit Dynamics only the composite generated in set up is being transfered and not the other geometry.
Please help!!
2156
1359
1150
462
