Can’t view my results in CFD-post
    • martzelp
      Hello, I am relatively new to Ansys, but so far I have hadn't any problems. However, for the last 3 days I receive this message about an ''application error'' and ''error opening file'' when I proceed to the results of my simulations. I receive the same message even on designs that previously worked correctly. When I tried to run these designs on a different PC, they run correctly, so there seems to be a problem with running the software on my PC. Does anyone know what may be causing this problem? Thanks in advance.
      Your PC can't see the project file. Did you change any folder paths? If you start a model from scratch (just need a box & solution) does CFD Post work?
      • martzelp
        No, I hadn't changed any folder paths. I also tried to start new designs but still have no results.
        Thank you for your response.
      Launch CFD Post from the Start menu and try opening a file from inside one of the Workbench folders, you're looking for a .dat.gz or .dat.h5 and a .cas file with the same name.
