September 13, 2022 at 8:50 pm
chengyan hu
SubscriberHello everybody,
I have now a problem with the capacitance extraction in the extension of Piezo and MEMS.
I followed all the sequence in the tutorial until this step: Insert the ''capacitance post processing''. In the definition column there is always no option, and only remains blank. But in the tutorial the capacitance extration from the analysis setting can be chosen.
All other options for the solution are good, so i am not sure where the problem could be.
The version i used is 2022 R1 student version, and the extension i used is the version for 2020 (seems the newest).
Looking forward for your answer.
Best regards
CH
September 14, 2022 at 12:17 pm
chengyan hu
SubscriberReinstalled and fixed
September 14, 2022 at 12:42 pm
Ashish Khemka
Ansys EmployeeThanks @Chengyan Hu for the update. Was reinstalling the fix? If you did follow any other steps then please feel free to share the same as other members too will benefit from this.
Ashish Khemka
- Maxwell, HFSS or Q3D?
- Error
2646
2110
1337
1118
461
