March 6, 2023 at 9:49 pm
Ashishkumar Gupta
SubscriberHi, I am doing Maxwell Electrostatics Simulation.
So how do I evaluate Capacitance at a particular location/node/point?
If I use the formula, it is C = Q/V. But how should I use it in calculator?
Thanks!!!
March 8, 2023 at 1:53 pm
Deyu Li
Ansys EmployeeIn Electrostatics solver, capacitance is calculated between two conductors by simlating the electric field that arises when a voltage differential is applied.
If you want to use field calculator, you can calculate the total electric charge on an object and divid the voltage value.
- Qty -> D (load D vector into the calculator);
- Geom -> Surface… (select the surface of interest) -> OK
- Normal
- Integrate
- number...->scalar->value: (voltage value)->OK
- Eva
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1861
1272
610
