March 23, 2021 at 6:53 pm
Korina
SubscriberHello, in the 1/8 stent model everything goes according to the tutorial and i get right results. When I tried to simulate the full stent model, i constrained the 8 faces of the edges of the stent on both sides, in order to prevent the motion in the axial and tangential direction. And I also used the deformation 0.3mm as in the tutorial. Is this constrain of the 8 faces right? Because in the lesson 9 of your tutorial I'm not sure I get the hint right.nnThank you in advance, nKorina Dedousi n -
March 24, 2021 at 5:00 pm
Ashish Khemka
Ansys EmployeennCan you please point out the link to the lesson you are referring to?.Thanks,nAshish Khemkan -
March 24, 2021 at 5:20 pm
Korina
Subscriberhttps://courses.ansys.com/index.php/courses/cardiovascular-stent/lessons/exercise-lesson-9/n -
March 25, 2021 at 7:40 am
1shan
Ansys Employee,nI don't think any constraint is needed for the edges of the stent. You could simply define the balloon deformation. Could you try this? There might be a chance that a rigid body error shows up, in that case change the contact from frictionless to no separation.nRegards,nIshan.n -
March 25, 2021 at 8:22 am
Ashish Khemka
Ansys EmployeennI have not looked at the problem yet but please try out Ishan's suggestion. It might help.nnRegards,nAshish Khemkan
Viewing 4 reply threads
Trending discussions
Top Contributors
2564
2078
1293
1106
459
Top Rated Tags
