December 7, 2020 at 1:21 am
Nolem
SubscriberI'm using the Academic Student 2020 R2 version of ANSYS and I'm following the online course as best as possible but every time I run the solver I get this error shortly after pressing solve.I've already tried reinstalling and restarting the project multiple times but I still get the same error in the same place. I've also tried solutions posted on similar discussions such as deleting/moving the temp folder.nn *** ERROR *** CP = 2.828 TIME= 16:47:40n An unexpected error ( SIG$SEGV ) has occurred... ANSYS internal data n has been corrupted. ANSYS is unable to recover and will terminate. n Previously saved files are unaffected. Please send the data leading n to this operation to your technical support provider, as this will n allow ANSYS, Inc to improve the program. nn Current ANSYS Traceback:n FirstLast n wprint n wbest n wsort3 n slvord n DomainOrder n solvcl n ANSYSn -
December 7, 2020 at 11:43 am
December 7, 2020 at 7:10 pm
Nolem
SubscriberSorry I forgot to mention I tried that and it still results in the same error. -
December 8, 2020 at 2:08 am
Nolem
SubscriberTurns out the error has something to do with the Academic version of ANSYS. Solved by going into Mesh and changing Element Order from Program Controlled to Linearn
- The topic ‘Cardiovascular Stent Project SIG$SEGV error’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
