May 19, 2022 at 9:36 am
Odebowale
SubscriberI am working on layered design and I have already extracted S-parameters for each layers to be used in interconnect. How can I represent each of the S-parameter elements in interconnect. I have tried different approaches, the results obtained is not similar to the one I obtained in FDTD. Kindly assists.
The main problem is how to properly represent two or more s-parameter elements in interconnect playing a multiplication role.
Thanks
July 6, 2022 at 4:25 amGuanhui Wang
Ansys EmployeeHi,
The s-parameters should just multiplex together if you connect them together. Could you please show your structure of design and how you want them to be implemented?
Viewing 1 reply thread- The topic ‘Cascading S-parameters’ is closed to new replies.
Trending discussions- Ansys Insight: About override mesh in FDTD: its use and settings
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
