Cd for circular cylinder
    • gaurav_shrivas15
      I want to calculate coefficeint of drag (Cd) using fluent; for the flow over cylinder in 2-dimensional domain:
      Dia of cylinder= 0.1 m
      Re=2x10^4
      what Reference values should I used in fluent to find the Cd as defaults values are 1 for
      area,depth and length.
      Area=?
      density=1.225
      Depth=?
      Length=?
      Velocity=2.93
      Viscosity=1.7894e-05
      When I calculated Cd using Report>Forces> cylinder wall>coefficient of drag. the results are not matched with available experimental results
    • Federico Alzamora Previtali
      Assuming that your mesh is fine and solution has converged sufficiently, your Cd will depend on those reference values that you have defined. I would imagine that the experimental results that you mention would have their corresponding values documented.
      • gaurav_shrivas15
        hi federico,
        my cd value is coming 0.78 where in research paper it is around 1.2 for  Re=2x10^4.
        this value coming when i am giving reference value as follows
        Area=0.1 (as diameter)
        density=1.225
        Depth=1
        Length=1
        Velocity=2.93
        can you give any suggestion so I can reduce my error?
          I assume you have set the same values as your upstream conditions (velocity and density). How many iterations have you run? Has your solution converged? Can you show a screenshot of your residuals and pressure field?
