cdb reading/exporting
    • desouzadacosta
      I am new to ansys mechanical/apdl . I found this attached .cdb and .dat files of arterial stent simulation.
      Wondering if I can export the settings and geometry for working inside the mechanical workbench .
      Any output is very welcome.
      Alex Costa
    • sk_cheah
      Hi Alex,
      This blog post by PADT should get you started.
      Kind regards,
      Jason
    • desouzadacosta
      Hi Jason,
      Thanks. I am attaching the translated .wbpz
      Do you have any clue about going further ?
      The contents of .dat can be interpreted within workbench ?
      Alex
    • desouzadacosta
      attached
    • sk_cheah
      Hi Alex,
      The CDB file contains the mesh etc while the DAT file contains the solution procedures etc. The method discussed above imports the CDB but I am unaware of how you can directly import DAT into Workbench. If it is appropriate for your problem, I would recommend solving it natively in Ansys classic.
      Kind regards,
      Jason
Viewing 4 reply threads
