Center of pressure
    • Alberto
      Goodevening,
      I've simulate a falling object inside a fluid volume (air) with dynamic mesh with only one dof  allowed (translation along vertical axis, z) . I've plot the Cp over the normalized spanwise direction of the seed (y-axis). What happen is that my Cp  range is between  è  [-7.5,13.5] and i know from theory that it must not exceed one.  Any idea on what happen?
    • Federico Alzamora Previtali
      Check the Reference Values in the physics tab
    • Konstantin
      Cp is scaled by the reference values you define in the reference values panel. First, check if those values are correct for your simulation. Second, Cp is scaled by a characteristic velocity, which becomes uncertain in your simulation. What is a characteristic velocity of a free-falling accelerating object before it reaches its terminal velocity? As its velocity increases and so Cp will vary. I'd say you probably should be using the terminal velocity as characteristic velocity, but the problem with this is it is not knows apriory. So what you can do when presenting results is state what characteristic velocity you used to scale it.
      Finally, Cp is used to define the pressure coefficient. Center of pressure is something else.
