Centrifugal pump cavitation
    • Jacob.bia3
      Good evening
      I'm doing a centrifugal pump cavitation on cfx server but i'm struggling to determine the boundary conditions for the cavitation case( i want to plot cavitation number with head).I have tried to run it with these boundary conditions:
      Case 1:
      Inlet: mass flow 5 kg/s.
      Outlet: static pressure 300000 pa.
      Case 2:
      Inlet: mass flow 5.
      Outlet: static pressure 1 atm.
      The head in case 2 is bigger than case 1 which is not reasonable because cavitation number decreases.
    • Jacob.bia3
    • sam
      Good morning, Jacob,
      Can you share your mesh setup if possible?
      For the boundary, the inlet should be your massflow and the outlet pressure gauge should be 0 psi. If you have pressure at the outlet, then cavitation is expected to happen
