CFD-DEM Fluent – Rocky
    • Vicky
      Dear Sirs,
      I am trying to simulate a two-phase flow in a horizontal pipe (air + solid particles), coupling Fluent software with Rocky software. It started with good results, but When the particle is 1 meter away from the starting point, it started to give me this type of message:
      Please can you help me solve the problem why the particles are re-entering the CFD domain?
      Thank you.
      What do the two domains look like? Overlap generally means you're trying to add a new particle where an old one is already present (it's a Rocky solver check).
    • Vicky
      Hello Rob,
      It looks like this:
      So, should I let the Software itself solve it? or is there something I can do?
      Thank you.
      Check the inlet region: can you get the particle flow rate into the domain through the area you've set? Remember there's a packing limit as DEM particles in Rocky occupy a finite volume.
    • Amirhossein Fardi
      What is your version of Ansys and Rocky ? I had same error in Version 2022.2 while everything ok in 2022.1
    • Vicky
      Hello, my version of Rocky is 2022.1 too.
      Regarding my mass flow rate, it is 0.00351kg/s and the pipe diameter is 30.5mm
      • Amirhossein Fardi
        you have two diameter. pipe diameter and cfd domain diameter. check the length and diameter of both geometries and sure both size are same.
Viewing 5 reply threads
