November 22, 2019 at 11:09 am
S1d996
SubscriberHie everyone,
I'm simulating 3D rotating body with sliding mesh and 6DOF.
while simulation is going on, it is showing a warning like....
Warning: incompatible interaction between moving mesh and dynamic mesh model detected!
Can anyone help me to resolve it?
Thanks in advance
Sid
November 22, 2019 at 11:26 am
Ansys EmployeeImages and some idea of what you're doing will help.
November 23, 2019 at 5:16 am
S1d996
SubscriberThanks for response rwoolhou
I have attached the images below
- First image is my input 6dof body (Propeller) which should move in +Y direction and circular discs are used as interfaces (sliding Mesh).
1. Hooking 6dof to Blade (which is defined as wall in BC) with 6dof-on, passive-off
2. Hooking 6dof to fluid Zone enclosing the Blade (which has all surfaces defined as interface). The only wall inside the zone is Blade.
here 6dof- on, passive-on.
3. When the relative motion is turned on along with point-1, the below mentioned warning is displayed in console area with the updated mesh motion .
Warning: dynamic mesh zone 19 (rigid body) with different CG uses 6DOF...
6DOF rigid body::libudf:: reference CG (6.21188e-01 6.21799e-02 -2.98251e-04)
6DOF rigid body::libudf:: different CG (6.21188e-01 6.19351e-02 -2.88150e-04)
Warning: dynamic mesh zone 17 (Rotating zone) with different CG uses 6DOF...
6DOF Rotating zone::libudf:: reference CG (6.21188e-01 6.15001e-02 -2.72000-04)
6DOF Rotating zone::libudf:: different CG (6.21188e-01 6.00420e-02 -2.682179e-04)
4. Have a doubt on which type of interface should be used while creating the interface zone between the discs so that the disc interface should move in accordance with the balde CG.
- The Secong Image is the Output of the simulation in which the Disc interface is not associated with the Blade Orientation.
November 23, 2019 at 7:44 am
DrAmine
Ansys EmployeeBlades and the fluid domain around them have to use the same rigid body udf. The domain does not enclose both in the picture -
November 23, 2019 at 7:52 am
S1d996
SubscriberThanks for reply
Im using same rigid body udf for fluid and blades and i didn't get the point what you have mentioned about " The domain does not enclose both in the picture"
November 25, 2019 at 6:24 am
November 25, 2019 at 6:37 am
DrAmine
Ansys EmployeeFluent detected contact and you did not define an UDF for that -
November 25, 2019 at 10:09 am
November 25, 2019 at 2:07 pm
Ansys EmployeeI think your problem is that the sliding interface is conflicting with the 6DOF motion. Try with a moving reference frame and see if that works.
November 26, 2019 at 5:11 am
S1d996
SubscriberThanks for the suggestions and i request you to give me a solution regarding my first issue
with regards
Sid
December 20, 2019 at 4:38 am
S1d996
SubscriberI wonder Why the Ansys Support Is to replying to any of the questions posted here.
S1d996
SubscriberVery Disappointing
December 20, 2019 at 9:40 am
Ansys EmployeeYou had the same problem with mrf and 6DOF?
December 20, 2019 at 11:30 am
S1d996
Subscriberi did'nt do the MRF model and the error was not seen with the 6DOF
December 20, 2019 at 11:58 am
Ansys Employeemrf and moving mesh?
December 20, 2019 at 12:10 pm
DrAmine
Ansys EmployeeAgain the help does state very clear and straight (User's Guide 11.1): Sliding mesh and dynamic mesh are incompatible if they are combined within the same cell zone or adjacent cell zones. If you want to combine these two models within the same case file, they must be separated by a non-moving cell zone.
December 23, 2019 at 6:57 am
S1d996
SubscriberThanks for the reply
As mentioned above, i removed the deformation of the outer fluid and the simulation ran smoothly till 0.1 sec
But, later the discs are moving apart as mentioned in above problem.
So, can u mention me where am i going wrong
Thanks in Advance
SID
December 23, 2019 at 11:29 am
Ansys EmployeeLook carefully at what is (and isn't) moving, and how they're related.
5264
3299
2469
