CFD of pump (Boundary condition )
    • obaid
      Hi everyone,
      i am doing a simulation for the pump ,i have my inlet boundary condition as a velocity inlet and outlet boundary condition as pressure outlet(0 gauge) my question is that
      1.when i open cfd post after solution, and when i see the contours of pressure at outlet it doesnot show me 0 gauge pressure it gives me some negative value.
      2.does the pressure in the results option shows the gauge pressure or absoulte pressure?
      thanks in advance to everyone
      If you're using Fluent just post process in Fluent: it's quicker & you have static, total & absolute pressure available without any guessing.
    • DrAmine
      1/gauge pressure+operating pressure= Absolute pressure
      2/Pressure in CFD-Post is the gauge pressure
      3/As rwoolhou  better to use Fluent if you are running Fluent for post-processing
    • obaid
      thanks sir,
      but this doesn't  answer my question , what i want to ask is that a pressure boundary condition is a part of setup or solution? if it is a part of setup then the pressure at the outlet has to be 0 gauge after the solution if not then it can change.
      Look at the multiple reference frame tutorial from the Help system: it's a compressor so same principle as a pump.
Viewing 4 reply threads
