December 9, 2020 at 3:13 pm
d.a.alaita
SubscriberHello,
I just ran a fluid flow in three phase gas-liquid-solid flow on Fluent 2020R1, but CFD post not able to read the cdat file. I got this error:
December 10, 2020 at 10:30 amRob
Forum ModeratorIf you read the case & data into Fluent 2020R1 and write out a cdat does it work? We have been changing the models with the more recent releases so it's possible something in the cdat phase definition has changed. nViewing 1 reply thread- The topic ‘CFD post 2020R1 not reading cdat files’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
