Ansys Products
Ansys Products
CFD-Post Blackscreen using Remotedesktop
    • PetervonMeter
      Hello!
      Following problem:
      I installed the new Ansys 2020R1 but CFD-Post shows me black screen.
      At first i thought it would be problem with the rdp-connection i use.
      But today i am at work for the first time in 3 weeks and had the chance to test this at multiple machines.
      I noticed that i got a black screen at a PC with a Nvidia GT640, ATI6850, Intel 4600, but a newer machine with a Intel UHD Graphics 630 worked, even over rdp.
      I updated all graphics driver no change. I set a varibale QT_OPENGL/desktop, cfd-post won´t even start.
    • PetervonMeter
      I solved it... it is a very strange bug.
      You must start Ansys (CFD-Post) local on the PC not over Remotedesktop. If you can´t get to the actual PC, you can use VNC-Server(as a service) und VNC-Viewer ( i used UltraVNC) to start Ansys CFD-Post. After that you can use a Remotedesktop connection and there will be no black screen...  .
      Moreover it didn´t work if you have installed more than one Ansys-Version. I deleted all Version and installed only Ansys 2020R1.
      If you close the rdp-Connection and open it again, than you have a black screen again.
      Why the bug didn´t appear on a new machine, i have no clue.
    • tsiriaks
      You can also try enabling GPU rendering for Windows RDP on Windows 10
      https://community.esri.com/thread/225251-enabling-gpu-rendering-on-windows-server-2016-windows-10-rdp
